Re: washerless faucets - two handled
Posted by Marvin on January 20, 19100 at 11:51:22:
In response to Re: washerless faucets - two handled
: : If you have a washerless faucet - two handled - why would the hot side not work and the cold side will - even after you have changed the valves and you know they are in correctly?
: Marvin, I assume you turned the valves back on under the lav. During this job a chunk of rust may have lodged in the valve or the faucet. All i can think of is take the hot stem out and open the valve under the lav while holding a cup over the faucet. Then you should know what is going on. Dale's Plumbing Service LMP
Dale, i've already tried that. water comes out of the valve really good. Once I put the cartridge back in, i still get none from the hot side. The cartridge is in correctly. Explain to me how the water gets from the cartridge and back over to the outlet. This i believe is the problem that i have. i think that i'm stopped up from the cartridge to the outlet or lav. is there any way of unclogging the inner parts of the faucet itself.
Replies to this post
There are none.
