Re: washerless faucets - two handled
Posted by Dale's Plumbing Service LMP on January 19, 19100 at 19:56:35:
In response to Re: washerless faucets - two handled
: If you have a washerless faucet - two handled - why would the hot side not work and the cold side will - even after you have changed the valves and you know they are in correctly? Marvin, I assume you turned the valves back on under the lav. During this job a chunk of rust may have lodged in the valve or the faucet. All i can think of is take the hot stem out and open the valve under the lav while holding a cup over the faucet. Then you should know what is going on. Dale's Plumbing Service LMP
