: Due to the recent cold surge in the Northease I have a pipe that is frozen. I tried using a propane torch to heat up the pipe and unfreeze it but that didn't work. Are there any other ways to unfreeze a pipe? J.Mills There are pipe thawing machines for this job. I used a welder once. I would not recommend that. I use a space heater pointed towards the direction of the freeze and have very good luck that way. As in all freeze ups you must be very carefull as not to burn your house down. All I can say is, use caution.Dale's Plumbing Service LMP
