| Posted by Dale's Plumbing Service on January 16, 19100 at 01:21:33: | |
| In response to Re: fiberglass shower pans | |
: Do they make shower pans with off center drains? I am installing a shower in the basement and the drain : is 14 inches from the wall which makes for a very small shower if it has to be in the center. Maurice, This sounds like it was a setup for a tub drain. You just may have to cut the floor over to the center of the shower drain and extend this pipe to that point and install a trap. They do make a shower pan that has a raised base to let the drain come out the back and down into the trap. Dale Peck LMP |
| There are none. |
