Re: dip tube particles again??
Posted by Dale's Plumbing Service on January 13, 19100 at 23:57:10:
In response to Re: dip tube particles again??
: Hi -
: My first floor tenants are seeing the white particles again in their faucets - I had the dip tube replaced in their water heater back in November - everything was fine until this week. They then started seeing the particles again - bigger chunks. It seems like the dip tube stuff again. Should I just have the heater flushed out again? or does this signal having to get a new water heater (and by the way this new settlement thing will make everything take longer) --
: Steph
Steph, I would check to see if it is indeed the dip tube first. It may still be some of the old dip tube. Then you will know what you have to do. It's all guess work until you know for sure. Dale Peck LMP
Replies to this post
There are none.
