| Posted by Chris Oertli on January 09, 19100 at 10:21:41: | |
| In response to Re: cultured marble shower repair | |
: I have a custom size (4 x 5 ft shower stall with entry at 45 degrees at one corner)on a wood floor. The base is a flat sheet of marble with side panels standing its edge against the wall. Over the years the seam has leaked and the subfloor is rotted. A repair in kind seems ill advised. Do you have a solution that prevents water leaks at the bottom of the panels? : Does anybody manufacture custom size shower bases? sorry, correct e-mail is; christian.oertli@cibasc.com : Chris
| There are none. |
