| Posted by Rachel on January 07, 19100 at 13:03:35: | |
I have two questions.. 1) We used Mono caulking a month ago to install a shower door and redo the caulking on the tub, but it is a mess. It looks worse than the stuff we took off! What brand would you recommend and is there a method that we should use? 2) Out shower door, the bottom rail, is warped. There is some space under it. When we put the caulking down it eventually lifts up and down because of the space. Is there any material we can put under the thing to either permanently glue it down or fill in the space? THANKS! |
| There are none. |
