| Posted by Dale's Plumbing service on January 06, 19100 at 21:42:24: | |
| In response to Re: removing bathtub | |
: I seem to have met with some difficulty in removing my tub to repair the walls and retile. my problem lies in : disconnecting the tub from the drain. the tub is 12-15 years old. I imagine it's a steel tub with a ceramic : coating. and the drain is a non pop up type. the tub is fairly light. the drain connects to the tub via abs : plastic pipes. the problem is that I cannot get underneath the tub to undo the pipes. is there a way to : disconnect the drain pipe at the top from the outside surface of the tub without having to get underneath to : unhook the pipes? does the drain in the tub pop out or unscrew to make removing it easier? : John in seattle John, There are a couple of tools that are made to remove the strainer from the tub. If the conventional ones don't work,Well i have had to use a hack saw or a sawsall.I wouldn't suggest you try that though. Dale Peck LMP |
| There are none. |
