| Posted by Dale's Plumbing service on January 06, 19100 at 21:38:38: | |
| In response to Re: sump pump | |
: Question: I've heard my sump pump running continuously the last 2 days. It all started after a hard rain but its not raining anymore. Is the pump stuck? Does it have an off switch? Right now I unplugged it for fear of it burning itself out but need to plug it in soon again before the next rain. : Help! : thanks Chris, Is the pump submergiable? Id the motor under water? If so the switch may be bad. If the motor is above water check and make sure the lift rod is not hung up. Dale Peck LMP |
| There are none. |
