Re: Island Plumbing
Posted by Dale's Plumbing Service on January 05, 19100 at 07:21:58:
In response to Re: Island Plumbing
: Need advice on plumbing an island. The main drain is at the outside wall and the island will be 6' away. The outside wall stack will have to supply the air, but my question is how do I make the loop for the drain? Is the air loop "y" taken off before the drain or after??? Thanks
Can you tell me where you found this drawing on the net. I looked all over for it and have seen it before but I failed to find it this time. I wanted to post it here also. Thanks in advance. Dale Peck LMP
Replies to this post
There are none.
