| Posted by Dale's Plumbing Service on January 04, 19100 at 07:37:16: | |
| In response to Re: bathtub venting | |
: Should a tub be vented after the trap or before the trap? I am approximately seven feet away from the main : stack with a two inch drain. L O'Brian, The code calls for this 2" line to have a trap arm no longer than 60". But between you and me It should work just fine as it is. Some codes would allow what you have already. Dale Peck LMP |
| There are none. |
