| Posted by Dale's Plumbing Service on January 04, 19100 at 07:33:44: | |
| In response to Re: Garbage Disposal Problem | |
: Terry, : Have a garbage disposal problem. I have an Insinkerator 333 and when I turn on I get nothing. No movement or anything....after a few seconds the shut-off takes over. I have hit the reset button a few times and looked and tried to see if there was anything in the disposal but I can't see anything...of course that doesn't mean anything since I know little or nothing about disposals except that I like when mine works!! Any advice would be appreciated. Derek, shut off the disposal. In the bottom of the disposal there is an allen wrench socket that you need to put an allen wrench into and see if you can turn the disposal manually. Also check the wire connections.Hope this helps. Dale Peck LMP |
| There are none. |
