Re: Eljer one piece toilet (Indiana 79E )
Posted by Dale's Plumbing Service on January 03, 19100 at 19:00:47:
In response to Re: Eljer one piece toilet (Indiana 79E )
: This Eljer toilet does not shut off water inflow. I have bent the float rod to no avail
: Where can I get a schematic showing the parts needing replacement in the float valve ?
Lew, you may have a piece of crud under the washer in the fill valve. I haven't worked on one of these but if it has a washer like most , take it apart and flush the fill valve out and turn the washer over and reasemble. Or you may have to go to a plumbing wholesaler to get a breakdown on this fill valve. Dale Peck LMP
Replies to this post
There are none.
