Re: replacing toilet floor flange
Posted by Dale's plumbing Service on January 03, 19100 at 07:56:14:
In response to Re: replacing toilet floor flange
: I just went to install a new toilet and noticed that the toilet floor flange is broken where the bolts attach from the toilet.
: The flange is plastic and our pipes in the house are pvc. The tolet seemed to be leaking also, possibly because the
: the flange is a hair lower than the tile floor which I presume was an afterthought. Nevertheless how do I install a new
: flange or is there another solution.
: Thanks
: grant
Grant, If the floor flange is 4" then they make a flange that fits down inside the 4" pipe and has set screws to lock it in and then screw the flange to the floor. If you have 3" they make a repair ring although you may have a problem useing it if the flange is below the tile. I have bought a plastic floor flange in the past, taken the metal off the flange and screwed it to the floor on top of the old flange. Dale Peck LMP
Replies to this post
There are none.
