| Posted by Dale's Plumbing Service on January 01, 19100 at 10:45:13: | |
| In response to Re: Water heater flushing | |
: In the past two weeks, I noticed my water starting looking a little rust colored. Thanks to this site, I now know I should have been flushing my water heater(how often???). I have flushed it 3 times so far, and it's still rust colored. I have a decent drain valve (copper, approx 1" dia), so w/the water-in and drain valve at full open, I get excellent pressure. My question is, how may times (if at all) will it take to get rid of all the sediment? Is there any other way to remove the crud, given I know very little about plumbing in general? If I need to call a professional, tell me -- I can take it!! By the way the heater is 10 yrs. old (A.O. Smith Water Products company -- 40 gal.). : Thanks - Bob Bob, You shoudn't have to drain your water heater or flush it to rid it of this rust. Flushing it means a gallon or two once a week or month. Something else is causeing this rust. Do you have city water or well water? The inside of the tank may be rusting out also. Have you been working on your water lines recently?If the rust persists you may need to install a filter on the cold water inlet. This is only if the heater itself is not rusting away.Dale Peck LMP |
