| Posted by Walter Benjamin on December 31, 1999 at 12:25:29: | |
| In response to Re: Back flow preventer | |
: : I have an underground lawn sprinkling system in New York City. Does it need a dual-valve back flow preventer, or is a vacuum-relief valve adequate? : Walter, It needs a double check on your sprinkler. Install a blow off for draining the system with air pressure in the fall. Dale Peck LMP : Thanks, Dale. By the way, I'm a NYC LMP, retired too long to keep up with modern code requirements. Walter B
