| Posted by Gene Wells on December 31, 1999 at 08:31:45: | |
HELP! As a marine aquarium hobbiest, I am considering installing a reverse osmosis system to provide pure water for the aquarium as well as for drinking and cooking. I have well water and the pump controls are currently set so that the house pressure varies from 22 psi to 45 psi. The RO system that I'm looking at requires input pressure between 30-40 psi. I could install a different control switch in the pump and set the on-off pressures to achieve that level but, the pump will start and stop consideralbly more often. Is there a water pressure regulator that I can install between the house supply line and the RO unit to equalize the pressure at around 35 psi? Or is there a better solution? I would greatly appreciate your input. Please provide as much detail as you can so I can get the best understanding possible(I need pictures-----sometimes!!!!Ha Ha!). THANK you in advance for your time! Gene. |
