Re: bleeding oil furnace burner.........help
Posted by Dales Plumbing Service on December 31, 1999 at 07:28:54:
In response to Re: bleeding oil furnace burner.........help
: i need to know exactly how to bleed my oil system for my furnace......just ran out and now it won't start,i had it filled ,but not sure how to bleed the line,,any help would be appreciated....thanks Todd, you don't say where your oil tank is located. If it is in the basement it shouldn't need priming. If you have a buried oil tank it should have a 2 pipe system (1/4") going to your oil burner and it should self prime.check your oil filter if you have one. they can stop the flow of oil to the burner if they are clogged with dirt.. Dale Peck MP
