Re: heated driveway
Posted by Dales Plumbing Service on December 31, 1999 at 07:17:32:
In response to Re: heated driveway
: can I use circulating water/anti-freeze mixture to heat an asphalt drive way? how deep does the pvc piping belong?
Larry, I would use entrim or pex piping to put the heat in the will need zones as you will not be abe to do it all in one loop. This system should be sized by an expert.the depth can be about 4" or you can pour the asphalt right over the tubing. Keep pressure in the lines and keep an eye on the guage to check for leaks as you pour.the tubing should be 1' apart. entrim is a soft rubber type tubing.Ted turner has about a mile of it installed in his ranch home in wyoming. Dale Peck LMP
Replies to this post
There are none.
