: When we removed the toilet to replace the wax ring the hole in the flange that you screw the toilet base to broke. Can you replace this flange without removing tile from floor. How is it attached? Threaded on to pipe, or is it glued on with some type of sealant? J. edmonds,there are repair floor flanges at your local plumbing supply houses. You don't say the size or what type of material we are looking at. Cast iron rusts away,plastic breaks. They have a floor flange that will fit inside a 4" pipe and you lock it down with set screws and screw it to the floor. Hope this helps. Dale Peck LMP
