Re: Moen single stem faucet replacement
Posted by Dale's Plumbing Service on December 24, 1999 at 16:08:36:
In response to Re: Moen single stem faucet replacement
: I am having a heck of a time removing the old cartridge. I don't see the clip anywhere to remove it. Any suggestions?
Ken, There is a clip there. clean with lime away and you will see it. I use a pocket knife to get it out if the hole on top of the clip is gone. You may need a moen stem puller to get the stem out. Clean opening with a wire brush. If your water is backwards after you put in the stem just rotate it 180 degrees.Dale Peck LMP
Replies to this post
There are none.
