Re: Low-Flush Toilet vs. Baseboard Heat
Posted by Dale's Plumbing Service on December 23, 1999 at 18:34:58:
In response to Re: Low-Flush Toilet vs. Baseboard Heat
: : We want to replace a Kohler Wellworth Lite installed in 1991 that doesn't flush well. We have baseboard hot water heat (finned tube) so the toilet must have 3" clearance behind the bottom part extending 8 1/4" up in order to clear the heating unit (12" rough-in). Just learned the Toto Drake we selected doesn't have enough clearance. I've e-mailed toilet manufacturers but haven't heard yet. Any ideas?
: Robin, Toto has a toilet that can be changed from 12" to 10" rough.That may give you the space you need. Or just a 10" rough in toilet.It would be better if toto would fax you a picture of the rough-in and then you can see how much clearance you would have. Maybe terry will post the info for you. It may be what you need. Dale Peck LMP
Replies to this post
There are none.
