| Posted by Dale's Plumbing Service on December 22, 1999 at 21:31:28: | |
| In response to Re: vents | |
: how do you clean out the air vents on top of the roof? : my toilet is not flushing well and I suspect a blockage. Leisha, You need to run a cable down the vent,for now run a hose ,if it is plugged up the pipe will fill. You may have a calcium deposit in the port holes under the rim of the toilet. Or your sewer may be partically plugged. Are you on a septic system? Dale Peck LMP |
| There are none. |
