Re: New toilets clogging speratically.
Posted by Dale's Plumbing Service on December 22, 1999 at 18:35:26:
In response to Re: New toilets clogging speratically.
: I have a new duplex. 3 toilets in each. Each toilet from time to time will clog when solids/toilet paper is used.
: My interpretation is there is not enough water "pushing" the solids through the toilet to the plumbing.
: Is this a common problem, and what can be done to fix it. New 1.6gal tanks. PVC plumbing that normally
: works fine.
G>T>, This is a common problem with these 1.6gal flush. There are several on the market and some say some are better than others. TOTO,geber, am standard are excellant. I also call these a 2 flush toilet. You might consider a power flus toilet. If not keep a plunger close buy. Dale Peck LMP
Replies to this post
There are none.
