Re: Bathroom Sink and Slow Drain
Posted by Dale's Plumbing Service on December 22, 1999 at 18:31:03:
In response to Re: Bathroom Sink and Slow Drain
: The bathroom sinks seems to be plugged up and drains really slow. I have tried Drano, two dosages worth. I can't pull the plug out to poke inside the drain. Any ideas before I tear the pipes apart under the sink?
Diana, If the lav is draining slow, there is an excelant product that i use to clear slow running drains. It is called THRIFT. You may need to have a plumber buy it from a wholesale plumbing suply. It works!Dale Peck LMP
Replies to this post
There are none.
