galvanic corrosion iron/stainless
Posted by Dicvk on December 20, 1999 at 11:43:06:
How much of a problem is galvanic corrosion with gavanized iron pipe and 302 stainless tubing?
I'm trying to install a Delta two handle Pressure balancing shower faucet into an old house with iron pipe supply lines from the attic on 8" centers. This will require about 15 to 20 threaded fittings or some fancy tube bending to get to the faucet inlets on the bottom over to one side.
How flexable is PEX tubing? would this be an alternative?
Replies to this post
There are none.
