| Posted by Metalex Pipes Limited on December 15, 1999 at 05:20:25: | |
Manufacturer Exporters of Galvanized & Black Steel Pipes & Tubes We introduce ourself as one of the leading Manufacturers Exporters of Galvanized & Black Steel Pipes & Tubes from 1/2" to 8" in Light, Medium and Heavy series confirming all international standards. We also manufacturers Light Gauges and thin mill Galvanized Steel Pipes & Tubes in classes A1 & A2 and square rectangular and profile pipes 1/2" to 4". We also Manufacturers Exporters of Cold Rolled and Hot Rolled Steel Strip in coils from 15mm to 600mm width and thickness 0.25mm to 2mm (in C.R.) 2mm to 6mm in H.R. AND Electro Galvanize Thin Wall Pipe 1mm TO 1.5mm in Dia 1/2" to 4" in class A1 & A2. Any requirement in above may, kindly Fax / email. With Regards, (S. Bhardwaj) METALEX PIPES LIMITED |
| There are none. |
