| Posted by Moore on December 09, 1999 at 19:30:08: | |
| In response to Re: Can't find these | |
Go to the CorningWare web page and see the material that is available You don't say what geographical area you're in, but you can try the Countertop manufacturers in large cities as well as cabinet top and hard surface contractors. They'll find them for you. : That material is Corning Ware made by Dow Corning and not Dupont. Dishes out of this stuff were called corelle, but i think the bakeware and other stuff was just called corning ware. : : These are not exactly plumbing problems, but hopefully there's enough remodoling experience around to help. : : I also think I want a built in cutting board or corelle insert in my kitchen counter. The cutting board fits into a cutout in the counter and has a stainless steel rim. The cutting boards used to be fairly commen in the early 70's and I know somebody made a similar unit with dupont correlle.(I may have the name of that material wrong, it's the stuff they make pots and baking dishes out of). Is there a reason they apparently don't make either of these anymore? : : If anyone knows where i might find either of these items , it would be greatly appretiated. : : Thanks,
