| Posted by Moore on December 06, 1999 at 21:01:47: | |
| In response to Re: Orangeburg pipe | |
The fact that you might or might not have Orangeburg isn't the issue. The issue is that the main line backs up and you want it to stop backing up. When the roto snake went into the line. the operator should have been able to give you a general location of where the obstruction was (is? is it still backing up?) When you know where the obstruction is, the repair is pretty simple, whether its orangeburg or clay or plastic or steel. The reason people say Orangeburg "inevitably" needs to be replaced is because it uses friction forced on couplings instead of glues or screwed fittings. Very fine tree roots look for water, and are able to penetrate the friction couplings, and grow inside the line. One roto rooter job each year to clear the tree roots cost what.......$50 to 95 dollars? or $100 to $200? that is less than the cost to dig up a sewer and repair it (or change from Orangeburg to clay). Anyway Orangeburg is still a good pipe fabricated in the 1950s made out of the Orangeburg minerals and soaked in creosote to ward off insects and roots. Sixty years of srvice is pretty good, but it'll probably go another ten if you roto snake it out every year. If you really need more Orangeburg information, email me at edcd@gte.net
: : Our house was built in the 1930s. I found a source on the Net that says Orangeburg pipe was manufactured during the Korean War. If that's true, we can't have Orangeburg pipe. Do you know if that source is right? : : We appreciate your help. Thank you. : Jerry, I don't know the exact date it came out but i built a home in 1963 and i think orangeburg was pretty new then. Yom may have clay tile for a sewer lone. You can have your line camered to see what material you have and also locate the exact place or the problem with your line.Hope this helps. Dale Peck. LMP
| There are none. |
