Re: Kitchen Garbage Disposer
Posted by Dale's Plumbing Service on December 06, 1999 at 18:10:18:
In response to Re: Kitchen Garbage Disposer
: We just bought a house and when we turn on the garbage disposer some of the waste we're trying
: to grind up comes up on the other side of the sink. I looked at the way it is plumbed and it appears
: that where the pipe that comes out of the disposer and the pipe that comes from the drain side of
: the sink meet a a Y then proceed to the p-trap. Is this right? It seems that the waste being ground
: up has a chance to come up the drain side of the sink before going on out of the house.
: Can anyone help on the plumbing configuration?
Anthony, What you should have is a center outlet waste with a baffle tee.If there is no baffle it can come up on the other side. Also your trap arm and waste line may need cleaning If it is an old galvanized or cast iron line. Dale Peck LMP
Replies to this post
There are none.
