| Posted by Dale's Plumbing Service on December 01, 1999 at 20:27:08: | |
| In response to Re: Uneven Toilet Flange | |
: In a house we bought after a few months we noticed : a water stain forming under the linoleum. We called : the home warranty company who sent out Rescue Rooter. : The 'plumber' stated that the toilet was leaking : He stated that we must tear up the floor in two : Are there any alternatives to this much work? The : In the meantime he inserted some 1/4" shims under the Steven, 3/8" is a bit off but I think it could be taken care of with an extra thick wax seal and use shims to level the stool. The leak between the tank and bowl was probably an accident waiting to happen. given the age of the bowl (not given)(I'm guessing)the gaskets between the tank and bowl are dry rotted and need to be replaced. I wouldn't blame the plumber for the leak unless he took the tank off the bowl. So bottom line is use a thick wax ring and shims to level and save your money for your vacation. Dale Peck LMP |
| There are none. |
