Re: Urinal intregal trap drain tie in
Posted by Dale's Plumbing Service on November 30, 1999 at 05:47:45:
In response to Re: Urinal intregal trap drain tie in
: How do the intregal trap urinals attach to the drain pipe? The unit has a 2" N.P.S. Tap which would be on the INSIDE of the wall.
: Also is reducing to 1 1/2 drain pipe a problem with a urinal with 1gpf? Thanks
Steve, There should be a 2" flange that screws on to the 2" mpt comeing out of the wall.There should also be a wall mount bracket. also there should be 2 bolts (brass) to go through 2 holes in the bottom of the urinal into the flange. you will need a urinal wax seal for the seal..Don't change to 1-1/2 as this is against the code and you may only create more problems for yourself at a later time. Dale Peck LMP
Replies to this post
There are none.
