Re: How to install new washing machine?
Posted by dale's Plumbing service on November 30, 1999 at 05:40:11:
In response to Re: How to install new washing machine?
: We're having trouble with finding out how to disconnect the water lines from old w. machine. Appears only way to do this is to turn off the main water supply. Can't seem to find a shut off valve around the w. machine area. Any ideas? Tina, You won't find any shut off valves for the water pipes leading to the wash machine. You will have to shut off the main water supply to perform this task. You should only have shut offs for the hoses to the machine.This is a standard installation.Dale Peck LMP
Replies to this post
There are none. |
