| Posted by Carla on June 24, 1998 at 15:48:53: | |
| In response to Re: INSTALLING SINK IN BASEMENT | |
: I would like to install a hairstyling sink in my basement. However, there is not enough room directly near the drain pipe as that's where the washer/dryer/water heater are located. ?Can I install about 10-15 feet from the drain pipe? The sink needs to be only about 3 feet from the ground. ?Where would the pipes go? Would cement have to be dug into? Many thanks. Hello again, To be more specific with my question, I am wondering if a pump might be needed to drain the water from a basement sink installed about level or below in the basement drain pipe. Thanks for any feedback you can give. Carla |
| There are none. |
