Re: Sump Pump Repair
Posted by Dale's Plumbing Service on November 28, 1999 at 13:29:44:
In response to Re: Sump Pump Repair
: There is a sump pump in the house we just purchased. It is used to move the sewage from the basement bathroom up to the street level where the city sewage is. When we bought the house there was a terrible noise when the pump shut off. I think this was the check valve making a knocking noise. At first it would make one knock. Then it began making two or more.
: Now the knocking has stopped but I am noticing that you can here some water flow back into the resevoir. Now the pump has stopped kicking on by itself. I can manually run the pump by a button on the power cord.
: I guess I am needing to replace the check valve. Is there also some fill valve that I will need to replace on the pump itself? How tough will this be? It is hard for me to know without opening the container and the way it is setup I will need to do that after I get the check valve out. The valve is in the pipe going out of the tank and there is very little play to get the valve out.
: Any help you can offer would be appreciated.
: Thanks
try this site out,Simplex Sewage Package Systems
910 Series - Choose your own package system for versatility and
warehouse storage.
Pumps - 264, 267, 268.
Basins - 18 x 30 polyethylene, poly-foam or fiberglass with 2" or 3"
vent and discharge.
Unicheck - Check Valve 2" cast iron or ABS.
912 Series - Prepackaged (Job Ready). Includes:
Pumps - 115V Model 264 or 266.
Controls - M (mechanical switch) or BN (piggyback variable level float
switch).
Basins - 18 x 30 polyethylene or fiberglass or 10' stack LA code
models with piping.
Consult catalog and price sheets for the specific components to match the job specifications.
IAPMO approval on polyethylene basins. Note: Polyethylene basins recommended for indoor
installations only.
Duplex Sewage Package Systems
Electrical Alternating System - Consists of:
1 - Electrical alternator.
1 - Duplex fiberglass or polyethylene basin 36" x 36" or
larger.
2 - 2" or 3" unicheck.
2 - Nonautomatic pumps.
3 - 10-0225 control switches or 4 when specified.
Mechanical Alternating System - Consists of:
1 - Mechanical alternator with or without alarm switch.
larger.
3 - 10-0015 - 115V / 1 Phase or 10-0016 - 230V / 1 Phase,
alarm when requested.
specifications. IAPMO approval on polyethylene basins. Note: Polyethylene
basins recommended for indoor installations only.
Replies to this post
There are none.
