| Posted by Cris on November 23, 1999 at 22:23:00: | |
| In response to Re: sewer gas | |
: What a detective you are! The floor drain is usually not able to let gas back from the sewer because of what is called a "Trap" that is designed to catch water as ti drains, and retain a little bit to effectively seal our return gasses.If you rarely send water down the floor drain, it is very likely it has dried out, and the remedy is simply to dump about three gallons of water down the drain. The very small flies breed in the moist humid environment of the sewer system and usually are prevented from entering the house by the water in the trap. You might try pouring a gallon of bleach down the drain to sanitize bacteria buildup in the sewer pipe after you pour a gallon or so down. The sewer gas is a toxic poisonous methane gas that is extremely harmful in large doses and prolonged periods of time. In the smaller doses you are getting, the methane gas could very likely contribute to your general lack of energy. Try pouring water into the drain, and monitor it for a week. If the flies stop, and gas odors stop, you might just need to pour water down the drain every month or so. Older houses experience a rusting condition in the trap where tha water has stood stagnant for a long time, and the trap leaks itsd water out and won't retain it even if you pour water in each day. In that case if you really need to have the floor drain operating, you might need to break out the floor and follow the drain away to a point where you can install a new trap, then replace the concrete. If the drain doesn't need to operate, you can buy a rubber stopper at a plumbing supply house, and screw in a stopper.
The black flies are called drain flies. They are harmless, do not bite and are more of a nuisance pest. |
| There are none. |
