Re: dual element elec hot water heater settings
Posted by Terry Love on November 22, 1999 at 12:13:21:
In response to Re: dual element elec hot water heater settings
 John, Both elements should be set the same. The lower element won't even come on until the upper stat is satisfied. Only one element works at a time. Terry : I have a dual element elec hot water heater. Should both the upper and lower elements be set at the : same temp. If not, what would be the correct settings? I have the upper set 5 degrees higher than the lower.
Replies to this post
There are none. |
