: I would like to install a toilet in my basement. The drain line comes down from the upstairs and goes into the concrete floor. Is there a way I can install a toilet and tap into the line without having to bust up the concrete? Don keeling, Hope this helps. Dale Peck LMP Qwik Jon System The Qwik Jon is a waste-water and sewage removal system that allows the plumbing contractor to put a toilet or complete bathroom almost anywhere . . . No need to break concrete or worry about gravity flow to the sewer main. Installation Is Easy! Here's What's Included:
Qwik Jon tank, lid & gasket. 2" solids-handling Zoeller-built pump. Floor Flange Extender Kit with wax rings. Check-valve. Discharge pipe to lid. Qwik Jon fittings and hardware. Step-by-step Installation Instructions. AVAILABLE MODELS Model 100 - Sewage Pump Model WM264, .4 HP, 115V, 9.4 AMPS. Model 102 - Sewage Pump Model WM266, 1/2 HP, 115V, 10.4 AMPS.
ENGINEERED VERSATILITY From the people who build the most complete line of sewage, dewatering, and effluent pumping systems in the business . . . Zoeller. So Many Applications . . . Basements New Homes Cabins Commercial Buildings Workshops or Garages Pool Houses Additions The Qwik Jon Breaks the Laws of Gravity . . . Now with the Qwik Jon, water and sewage waste can go uphill, which means you can install a bathroom almost anywhere! The Qwik Jon pumps in any direction, is very quiet, and is leak-proof and odorless. Tank and all piping can be hidden. The Qwik Jon can be installed free-standing on any solid level surface, or the tank and all piping can be hidden behind a wall and under a 2" x 6" subfloor. No one need ever know it's there. The Qwik Jon is tough, sturdy and designed to be built in. Top of Page | Zoeller Corporate Home Page | Zoeller Pump Co. Home Page | Company Profile What's New at Zoeller | Zoeller Pump Co. Products | Contact Info Comments | Trade Show Info | Technical Support | Order Form
Web pages created and maintained by Zoeller Company � 1997 Zoeller Company. All rights reserved. Send information regarding this web site to webmasterzoeller.com
