Re: reinstall new shower base
Posted by Dale's Plumbing Service on November 20, 1999 at 05:51:07:
In response to Re: reinstall new shower base
: I need to install an acrylic base on a slab foundation. There is a 2'x2' hole for the drain in the slab. Can I fill this in with p-gravel or frame it out with 2x4's and durarock?I need to set the base in concret and would like some support in the center around the drain. Bernie, If the waste lines up with your new base drain then put a coffee can (large) around the pipe and concrete the hole up.Then take the can out and install the base. Dale Peck LMP
Replies to this post
There are none. |
