: I am trying to find a solenoid valve that I can attach to an electrical switch to basicall turn on or off a 1/2" water line. Where can I find such a thing (local plumbing supply house said they never heard of such a thing...) SPECIALTY & CUSTOM DESIGNS FROM CFA & FLUID AUTOMATION SYSTEMS Media Isolated 2-WAY INERT 0 to 46 psi Cv to 2.52 Orifices to 5/32 inch PVDF, Stainless Steel, Kel-F, Delrin, Polypropylene bodies Buna, Viton, EPDM, Silicon diaphragms 10-32 to 3/8 inch NPT ports standard 3-WAY INERT 0 to 100 psi Cv to 0.13 Orifices to 3/32 inch PVDF, Polypropylene bodies Buna, Viton, EPDM, Silicon diaphragms 10-32 to 1/8 inch NPT ports standard Pinch FLEXIBLE TUBE Normally Closed & Normally Open Up to 1/4 inch O.D. flexible tubing Also for vacuum Aluminum & Stainless Steel bodies Single and Double Tube Chasis mount optional Proportional MICROPRO 2-way Normally Closed Up to 174 psi Cv to 0.063 Orifices up to 3/32 inch Nickel Plated Brass bodies Buna, Viton, EPDM, Kalrez seals 10-32 inline & manifold mount
High Flow SERVO 2-way Up to 145 psi Cv to 1.54 Orifices up to 1/4 inch Brass, Aluminum, Stainless Steel bodies Buna, Viton seals 1/8, 1/4, 3/8 inch NPT ports standard
Sub-Miniature PICOSOL 2-& 3-way Up to 100 psi 0.021 Cv Ryton bodies Buna, Viton seals Manifold mount Electrical connection by Lead Wires or Connector
Intrinsically Safe MICROSOL IS 2-& 3-way Up to 100 psi 0.008 psi 1/64 inch orifice Ryton body Buna seals Manifold mount
DC Magnetic Latching MICROLATCH BACOLATCH 2-& 3-way Vacuum to 2030 psi Orifices to 1-5/16 inch Brass, Aluminum, Stainless Steel, Polyamide bodies Buna, Viton, Ruby, Teflon, EPDM seals 10-32 to 2 inch NPT ports standard In-line or Manifold
Push MICROSOL up to 3/4 inch extension 14 to 145 psi Ryton, Zinc bodies Brass, Aluminum, Stainless Steel, Polyamide bodies Buna seals In-line or Manifold
High Vacuum BACOSOL 2-way; Bi-directional 760 (min.) to 10-6 (max. Torr) 0.77 Cv 13/64 inch Orifice Brass body Buna seals standard DN 10 KF port 1x10-9 leakage
Interface/Booster HIGH FLOW 2-& 3-way 1.4 to 145 psi 1.4 Cv Orifice to 5/16 inch Ryton, Aluminum body 10-32 to 3/8 inch NPT ports standard In-line & Manifold mount
Return to CFA HomePage Describe your Application
Components For Automation, Inc.
4525 East Industrial Street Unit 4C Simi Valley, CA USA 93063 tel: 800-582-4232 fax: 805-582-0210 e-mail: gcvalves@worldnet.att.net Hope this helps,Dale Peck LMP
