| Posted by Dale's Plumbing Service on November 20, 1999 at 05:10:29: | |
| In response to Re: Sewage ejection tank | |
: : When my house was built 5 years ago, the builder installed the rough plumbing for a bathroom in the basement. A sewage ejection tank was plumbed in and they left behind the two rubber gaskets for the waste pipe and the vent pipe, but not for the electrical line for the pump. Does anyone know where I can get a gasket or grommet to seal this hole which is 2.5 inches in diameter> : Greg, Call your local plumber and have him get you this gasket. It comes in a package with all 3 gaskets,a sealer for the lid and new bolts. Shouldn't cost very much. Don't forget to use a 2" check valve and a 2" ball valve on the ejector side and also vent this pump can.Hope this helps. Dale Peck LMP
| There are none. |
