| Posted by Dale's Plumbing Service on November 16, 1999 at 21:36:55: | |
| In response to Re: Clogged Washing Machine Drain. | |
: Do you have any advice on unclogging a washing machine drain? I have tried almost everything from chemical solutions to a drain auger(snake). : Thanks for the advice. PTN, If you could tell me the type of pipe you have for your washer ex..cast iron,copper,or pvc pipe. the age has a lot to do with it also. and the installation has a lot to do with how you clean this line. I would call a licenced master plumber and have him look it over and tell you what should be done. you may need more than a simple drain cleaning job. Dale Peck LMP |
