| Posted by Carla Hegenberger on June 22, 1998 at 12:36:55: | |
I would like to install a hairstyling sink in my basement. However, there is not enough room directly near the drain pipe as that's where the washer/dryer/water heater are located. ?Can I install about 10-15 feet from the drain pipe? The sink needs to be only about 3 feet from the ground. ?Where would the pipes go? Would cement have to be dug into? Many thanks. |
