| Posted by chris m on June 20, 1998 at 23:54:36: | |
I purchased an expensive (newport brass) deck mounted faucet for my new whirlpool tub but it didn't come with any connecting hoses (to connect the tub spout to the valves). Is that normal? I would rather not use flexible plastic hoses because it will be nearly inaxcessible if they should leak. Is sweated copper pipe the way to go? What about connecting the two valves to the tub spout...do I just use a regular "t" connector? Thanks very much....chris |
| There are none. |
