Re: Refill valve not working?
Posted by Dale's Plumbing Service on November 11, 1999 at 23:21:00:
In response to Re: Refill valve not working?
: I just replaced both the refill and flush valve on a 10 yr old toilet. Now the water level keeps rising after the refill valve "closes" and then iverflows down the fluch valve. There is a hiss coming from the refill valve. Ideas? Dan shut the water off under the stool and take the top of the ballcock apart and hold a cup over the opening and turn the water on and flush the line. then check to make sure you have no nicks in the new washer. Replace as needed. Dale peck LMP
Replies to this post
There are none. |
