Re: banging bathroom pipes
Posted by Dale's Plumbing Service on November 11, 1999 at 23:13:45:
In response to Re: banging bathroom pipes
: When the hot water is turned on in the bathtub the pipes begin to bang. I tried turning on the cold water first and then add the hot water slowly. Sometimes it works and other times it doesn't. What causes this banging in the pipes?
Marie, It sounds like the screw came loose on the hot water side stem. Take the stem out and see if i'm right. Check the cold also and if there are 3 stems check the middle. Dale Peck LMP
Replies to this post
There are none.
