| Posted by Dale's Plumbing Service on November 11, 1999 at 22:59:29: | |
| In response to Re: bending pvc pipe | |
: Dear Terry, : Can one inch schedule 40 PVC pipe be bent slightly (about 20 degrees or so) by heating it with : Thanks, : Barrie Mathason I'm not Terry but I'll try to help. You should Install the pipe as recommened by the manufactures specifications. Installing PVC in a snake like way is recommend because it expands and conntracts. I don't know how sharp of a bend you are making in a short area and I do not know if heat will shorten the life of the pipe. Hope this helps. Fittings are recomended. Dale Peck |
| There are none. |
