Can one inch schedule 40 PVC pipe be bent slightly (about 20 degrees or so) by heating it with a heat gun without compromising its ability to hold cold water at 50 psi? If so, what is the minimum radius of bend that you would reccommend? I would also apperciate any pointers you might give on doing the actual bending.
