| Posted by Bruce Martin on November 06, 1999 at 09:41:44: | |
| In response to Re: Kohler SAN RAPHAEL Power Lite | |
: : : Usually a power flush toilet requires a certain amount of pressure in order to charge the pressure tank. I would concider the Toto Ultimate that is shown at this sight. It is a gravity Toilet that performs as a power flush toilet. Make sure you ask the person you are buying the Kohler from about minimum pressure requirments. : : The spec sheet on the Kohler Web Site says "Minimum static pressure required - 15 p.s.i." for the Kohler. If you are concerned with water conservation, the Toto unit is almost impossible to flush while using the Federal 6 liter maximum. To do so you mus hold the tip lever down no longer than 0.9 seconds. Longer hold downs will result in two to 2-1/2 gallons being used.
| There are none. |
