| Posted by peter on November 04, 1999 at 14:41:23: | |
| In response to Re: Squealing Pipes | |
: On an irregular basis, when a tap is used, a high pitched squealing, whining type of noise is heard throughout : the house. Sometimes it goes away when you quickly run a tap (either hot or cold) and then shut it off, : but not always. It seems to be getting worse. The only "cure" for it right now is to flush the toilet, but : this could get expensive if we have to keep flushing to stop the whining. It has progressively gotten worse : over the past two months and it happens at least once per day. There doesn't seem to be a particular : faucet that starts it off, and sometimes it just does it all by itself. : Any suggestions on where to start??
| There are none. |
